Bulkhead heat
SavageXL85
Anybody else's bulkhead get really warm to the touch??? I've never noticed it before just seeing if it normal
upbasher1
HPISF Supporter
Ironwood, Michigan
Both or just the rear? If its just the rear it may or may not be just heat from the exhaust header...they get pretty hot lol
If its the front too, you might have some unwanted friction going on in your differentials, time for re-lube?
SavageXL85
Hmmmm didn't try the front I'll check it today... have a brushless conversion so not header. I'll also check the lube ...been using chain wax not sure if that has anything to do with it
upbasher1
HPISF Supporter
Ironwood, Michigan
Could be a bearing going bad creating a lot of friction, they get toasty quick if theyre binding up
