I HAVE THE SAME CLUTCH SET UP LIKE U DO,I HAVE A STS.28 MOTOR,WHAT DO U SUGGEST SHOULD I REMOVE THE HEX SCREWS AS WELL?OR SHOULD I JUST GET A STIFFER SPRING?THANKStrashard said:check the springs again if they`re mounted properly if they`re ok, try stiffer springs.
the HPI clutch set had small hex screws with it, they`re meant to change the weight of the shoes.
a heavier shoe will engage faster than a light shoe, if your clutch set has them as well, take them out.
