When you say work, do you mean move? Spin freely? No power to them?
Grub screw is usually the culprit.
ok when i turned it on i saw the two front wheels spin only anyideas ???
Do you mean under throttle?
I am going with my first assumption and say it's the grub screw. Very common on Savages. Check the small screw that goes through your pinion. It's probably missing or broken. Replace it and loctite it good.
