.28 traxxas engine by Tecnomeccanica from italy
Clifffff
Several of friends have purchased the .26 and .28 tecnomeccanica traxxas engines. Has anyone heard of tecnomeccanica and is familiar with these engines? From my research I gathered tecnomeccanica does oem for other RC companies and even automobile manufacturers. They are based in Italy and are directed by Rody Roem.
These are the specs I found:
Tecnopower .28 Traxxas Engine Specs:
  • capacity .28 Ci 4,8 cc
  • ports 4 + 2 = 6 ports and 2 cooling-holes
  • ABC setting , aluminium/bronze/chrome
  • hardened 14 mm crankshaft
  • tuned and timed crank
  • aluminium light weight conrod
  • double bushings conrod
  • CNC manufactured burn room
  • Inox STD glow-plug
  • alloy shaped cooling-head 10 fins
  • short 7 mm carburettor
  • 14 mm steel main ball-bearing
  • stroke 17 mm
  • bore 21 mm
  • 38.000 rpm
  • 3,2 Bhp
  • full cnc manufactored engine mount for Tmaxx or revo
  • nitrated gears for electric EZ start
  • Mabuchi 380 electric motor for ez start
Tecnopower .26 Traxxas Engine Specs:
  • Mabuchi 380 started
  • engine mount of choice for Revo or tmaxx
  • CNC machined out of full aluminium engine mounts
  • capacity .26 (4,5 cc)
  • Bore 21 mm case
  • bore liner 17,8 mm
  • stroke 16,8 mm
  • tuned crankshaft
  • aluminium carburettor
  • cnc machined double bushed conrod
  • Port 4+2 ( 6ports) and 2 cooling holes
  • seperate Inox Burnroom with Inox glow plug std
  • 14 mm main bearing steel
  • hardened gears for electric ez starter
  • alloy cooling head 10 fins shaped
Does any of you have any input? I am thinking of getting the .28 to test.
here are some photos...
The .26 has purple cooling head
The .28 has silver cooling head
For $210-$230, I wouldn't want to be the guinea pig. Post a video if you end up with one. Not that I need it, but would still like to see it in action.
I have the 21Tm in one revo and an LRP28S3 in my other with a new era leaner mount. I don't drive any of my nitro's much anymore. Couple times a year at most.
I placed my order. I will make a few clips for sure and will definitely push it to its limits.
yes I did. The shipment took 10 days to the US from Europe. The engine came well packed and with a sheet of instructions for breaking it in. It is a direct fit for Revo. So installation was very easy. I followed the instructions to the letter but in the end all was worth it. The engine is very powerful, one might say, almost too powerful!!! The torque is simply insane. I might drop the EZ start though and go with pull start. I really think EZ start motors cannot bear the brunt of big block engines and easily get damaged in the process.
I am in the process of making a short clip. Should be done next time I go to the track.
