2 speed not shifting
David Masson
Hey guys, I am new to this thread and new to savage. But not new to RC. Anyway, I have recently bought the savage 4.6 and it seems that it stopped shifting. I tried adjusting my 2 speed but it still not shifting. Any advice would be great. I also looked into YouTube to no avail. Thanks in advance guys.
the 2 speed outta be close from the factory, shifting is dependent on :ercm: rpm also so if it is still kind of new it may not shift till you finish breakin and tuning the :ercm:
also make sure you are turning the actual shift point screw and not the hub screw that holds the 2sp assy on the shaft....
one is 2mm for the shift screw and the hub screw is 2.5 mm, when adjusting you make 1/12 adjustments at a time.... it is very easy to turn the screw past the sweet spot so care is needed here....
Thanks for the reply!!! Yeah, break in is way past done. It will just only stay at one gear and then have a high pitch. I did watch on YouTube how to adjust it. And I did do it the way that you just mentioned. And I did go past that sweet spot I guess because the nut and spring came out while it was runningand it got stuck between the gears. Luckily nothing was damaged. I replaced the spring, small ball and nut but still it won't adjust. I'm thinking should I just replace the gears? The truck is practically new less than two months.
