Zane Lewis
It’s the .25What engine is this for?
Ok thanksThe original back plate is discontinued the 1426 part number is the correct new part number.
I had the same exact break, and on the same part twice. Ditched the Rotostart to a pull start and it hasn’t happened sinceI’m am concerned about the back plate on the hpi. I’ve looked at the part number and found a match, but to me I think it’s a little off. I’ll list above what it looks like and then show you the replacement.View attachment 7828
Yes sorry it took me so long to respond here’s the link below..That small slot in the original plate matches with the spring and pin in the crank at the base of the piston......... is there anywhere that sells the spring and pin?
Many thanks. Found that Wheel Spin Models in the UK sell them too.Yes sorry it took me so long to respond here’s the link below..
http://www.activepowersports.com/hpi-racing-starting-pin-pressure-spring-1433/
