FOXSHOXRACING
Hey new to the forums here, but I got some problems with my Savage X My savage is having more issues, I had the carb set at factory settings and it was running, not good though, and it would have a ton of smoke and bog down like crazy, it also would not idle. I ended up leaning out the HSN a bit after the motor was warm-ish and it seemed to help it rev a bit higher, so then I leaned out the LSN a little bit, only like an 1/8 of a turn, and it would accelerate faster but then it would stall and die after getting off the throttle at all. If anybody can help at all it would be very appreciated, thanks.
