Nice clutch setup @thesmilingpirate , keep in mind that alloy shoes do need frequent maintenance to perform correctly....
Could you elaborate a little more on this? What maintenance are you referring to? Thank you
Alloy shoes have a tendency to wear at the leading edge a bit, every few runs I take mine down and remove the flashing that develops from use, a bit of filing the edges will keep the shoes from hanging up as they do wear.... sorry I don't have any pics of this, but you will know when you remove the bell the flashing will be pretty evident....
I've had a couple sets of the dynamite max lifes. They wear really well and don't get much of a burr on them. I rarely mess with them. I have a set in my 21Tm revo at the moment because I bought it used and it has MIP center axles so I can't move the trans forward to install an 1/8th clutch setup on it like my big block revo. I've got over a gallon on the set in there now and haven't had to debur them yet.Alloy shoes have a tendency to wear at the leading edge a bit, every few runs I take mine down and remove the flashing that develops from use, a bit of filing the edges will keep the shoes from hanging up as they do wear.... sorry I don't have any pics of this, but you will know when you remove the bell the flashing will be pretty evident....
