no go
London idiot
London
HELP not savage but bullet 3.0 car was flying suddenly cut out turns over but won't fire yes there is fule in it
Check/ replace the glow plug. Check glow plug igniter battery, charge it if low. I could go on and on, check those first though.
Cheers tried that seems like fuel not get through taken line off ok carb gap fine ??
your information is seriously lacking here, maybe a few clear pics and even a video may help here.....
check your fuel line for obstructions and if necessary replace it.... could be a clog of congealed oil in the line or carburetor....
Ok car going fine middle of high speed straight cuts out 1/2 tank of fuel will not start again turns over will not fire test glow plug test fuel line every thing seems ok but won't start
I asume that he is translating his comments with Google translate. I have difficult to write in english, but i try to explain the best I can. @London idiot you need to provide more details.
Check for air leaks, in exhaust, make sure fuel is still flowing in the carb, check backplate for tightness, and also check cab settings, especially idle, change glow plug, a plug may still glow, but may be weak, and not work properly,
Ok guys thanks for your inputs looks like a complete strip down as there are some very funny noise coming out of it
Thanks for all your help and suggestions half way through a strip down apart from all the crud broken cluch spring
