Do you by chance have a part # for that part, the battery indicator for the SavageI would consider this to be one of the best upgrades that I have done..It takes the guessing out of when you hump or battery pack is going to die on you..
Ok got that part number, do you by chance have a part # for the battery box that goes on?
Also do you have a part # for the switch that goes on it and does it snap in? I called HPI and they would not give me that info, any you provide will help, thanks.
aaah...got cha...yeah i know that all it sees is 6volts..however i wasnt aware that the rechargable pack was only 1.2volts per cell. i thought they was all 1.5 volts, one just rechargeable..i learned something today!!thank you. that makes more sense to me now. I'm going to try it out here in a bit I'm about to leave work..and thanks again man4AA cells x 1.5 volts = 5 NiMH cells x 1.2 volts = 6 volts. The indicator will read the level of any 6 volt pack on it's scale since that is what it is made for. It doesnt know where the 6V is coming from..
I just went to my local hobby shop and theyhave a veriety of universal power switches that have the built in charging port coming from it. i bought one cost me $7.00 plugged it in...installed my led battery indicator and everything works sweet. and the charge port dosnt snap in the box cover..theres 2 little "L shaped" plastic peices that comes with the RTR savage or if u buy a complete battery compartment it comes with them..you sandwich the charge port between the plastic peices, then find 2 little screws and theres 2 spots under the cover where u install it. then put the rubber plug back in to keep dirt and debris out while bashing.have fun11Also do you have a part # for the switch that goes on it and does it snap in? I called HPI and they would not give me that info, any you provide will help, thanks.
