- Location
- Dekalb, IL 60115
Had an old Savage 25 chassis... Got bored and built this baby....brand new Lrp zr.30 spec 2.. 3speed tranny with high speed 3rd gear, savage flux diffs, blast wheels with phaltline tires, etc etc...gonna do engine break in tomorrow... Should be a beast
I'm loving the 19, little less wheel spin on the take off. Def more speed on the straights. Might thicken up my diff fluid as well, torque steering like mad. Right into mad trees!Decided I need a bigger clutchbell. Put 60k in the rear and rebuilt the shocks. Need to got to 18 or 19 CB to keep off the lid.
Ya everything was fine other than the castor block. As for the hub/axle carrier I'm not sure, I bought it years ago. they may be Integy but I'm not sure, it's not labeled. Put them through a lot of abuse though, never bent or broke one yet. Bearings fit perfect too. I have it all back together now but next time it's apart I'll take a close pic of it and maybe some one can identify it. I would def recommend them, good tough partYikes, @Bauerdog ! I hope the shock is ok, at least. What kind of axle carrier is that, by the way?
Doesn't have that hex hub end, and it has pins and clips to pivot.Definitely looks like the integy part.
http://www.integy.com/st_prod.html?p_prodid=6413&p_catid=147&ratesortby=New#.VytV6oQrJD8
True I bought it years ago, off a shelf in some LHS that I don't even rememberUnfortunately Integy has changed designs a few times in several years. Possible that yours is Integy, but an older design. I know my rear hub carriers look nothing like what they currently sell.
Looks like it was about time to pull the engine and clean/inspect stuff anyway.
