Servo saver
Coreyscott88
i bought a new hpi octane (first gen) I snapped the upper and lower control arms the shock and the servo saver counting the piece that the ty rods hook too got it all back together will steer left but not right when I kill all power I can turn it by hand left and right when I turn the wheel right it bounces back to straight the 2 pieces of the servo saver are coming apart tried to tighten spring nut still lets it separate when I turn it right by hand can anyone help
Try putting loctite on the brass sleeve of the servo saver this way the nut won't loosen up becarefull not to make it to tight or you will burn up the servo
