HPI Savage Flux HP Manual (model #: 109073): http://hpiracing.com/instructions/flux-hp (mirror)
Chassis Components
#100902 - MAIN CHASSIS SET 2.5mm
#100908 - BATTERY BOX SET (RIGHT/LEFT)
#100909 - BATTERY BOX MOUNT / COVER SET
#102089 - FOAM SHEET/BLOCK SET (4pcs)
#102272 - COMPOSITE GEAR BOX/BULKHEAD
#106743 - BATTERY BOX HOLDER/MOUNT SET
#85052 - CENTER GEAR BOX CASE
#85059 - BUMPER SET/LONG BODY MOUNT SET
#85234 - SKID PLATE/BODY MOUNT/SHOCK
#85236 - RADIO BOX SET
#85239 - ROLL CAGE SET
#85245 - WHEELIE BAR SET FOR SAVAGE
#86048 - UPPER ARM BRACE 4x54x3mm
#86067 - BULKHEAD LOWER PLATE 2.5mm
#86070 - LOWER ARM BRACE 4x54x3mm
#86803 - JOINT POST 4x6x74mm (2pcs)
Drivetrain
#100905 - IDLER GEAR 44T / SHAFT SET
#100919 - PINION GEAR 20 TOOTH (1M / 5mm
#102088 - PINION GEAR 25 TOOTH (1M / 5mm
#102093 - HEAVY DUTY SPUR GEAR 44 TOOTH
#102692 - MACHINED BULLETPROOF DIFF
#72130 - STAINLESS STEEL SLIPPER PLATE
#72131 - SLIPPER CLUTCH PAD (2pcs)
#86032 - BEVEL GEAR SET (GEAR DIFF)
#86056 - DOGBONE 8x84mm (BLACK)
#86057 - DOGBONE 8x78mm (BLACK)
#86066 - HEX WHEEL HUB 14mm
#86081 - GEAR SHAFT 6x12x78mm (BLACK)
#86082 - CUP JOINT 6x13x20mm
#86083 - CUP JOINT 8x19mm (BLACK/2pcs)
#86084 - DRIVE GEAR 32 TOOTH (1M)
#86089 - DRIVE SHAFT 6x70mm (BLACK)
#86094 - SCREW SHAFT M4x2.5x12mm
#86095 - SCREW SHAFT M5x3x18mm
#86097 - DRIVE GEAR 18-23 TOOTH (1M)
#86098 - IDLER GEAR 29 TOOTH (1M)
#86099 - DIFF CASE WASHER 0.7mm (6pcs)
#86130 - SLIPPER CLUTCH HUB
#86246 - SUPER HEAVY DUTY DRIVE SHAFT
#86248 - SUPER HEAVY DUTY DIFF SHAFT
#86804 - HEX WHEEL HUB 17mm
#86827 - ALLOY DIFF CASE
#86928 - SUPER HEAVY DUTY AXLE 8x11x44mm
#87042 - SPRING 4.9x8x7mm/WASHER 4
#87043 - RUBBER CAP FOR GEAR BOX (2pcs)
#87193 - 4 BEVEL GEAR DIFFERENTIAL
#87194 - SHAFT FOR 4 BEVEL GEAR DIFF
Suspension & Steering
#100948 - SHOCK BODY SET (113-157mm)
#100949 - SHOCK PARTS SET
#100950 - SHOCK SHAFT 3.5x90mm (4pcs)
#100961 - SHOCK CAP SET
#102365 - BIG BORE SPORT SHOCK SET
#6561 - SPRING 18x20x1.7x5 (BLACK/2pcs)
#6811 - O-RING 6x9.5x2mm (BLACK/8pcs)
#75075 - SILICONE O-RING S4 (3
#75080 - O-RING 7x11x2.0mm (BLACK/8pcs)
#85048 - UPRIGHT SET
#85058 - STEERING CRANK/SERVO SAVER SET
#85231 - SHOCK SPACER PARTS SET
#85238 - SUSPENSION ARM SET
#86059 - BALL 6.8x7.3x3mm (BLACK/4pcs)
#86071 - FLANGE SHAFT 4x62mm
#86073 - SHAFT 4x78mm (SILVER/2pcs)
#86074 - SHAFT 4x46mm (SILVER/2pcs)
#86090 - STEERING CRANK POST 6x49mm
#86319 - STEERING POST 12x47mm (PURPLE)
#86551 - SHOCK SPRING 18x80x1.8mm 14
#87058 - RUBBER TUBE 3x8x10mm
#87500 - BLADDER 16x5mm (FLAT
#87524 - RUBBER BUMP STOP (4pcs)
#93535 - TURNBUCKLE M4x70mm (4pcs)
#Z599 - SCREW SHAFT 3x40mm (4pcs)
Electronics
#100684 - FLUX BLUR ESC
#100685 - FLUX TORK 2200Kv BRUSHLESS
#100903 - MOTOR MOUNT PLATE 8mm (GRAY)
#100906 - MOTOR PLATE 3.0mm (7075/GRAY)
#100907 - MOTOR MOUNT BRACE 7x7x80mm
#104058 - HPI TF-20E 2.4GHz TRANSMITTER
#104059 - HPI RF-20 RECEIVER (2.4GHz
#104085 - 2.4GHz RECEIVER ANTENNA 300mm
#113126 - ELC-6S WATERPROOF ESC
#Z150 - ANTENNA PIPE SET
Hardware
#6203 - BODY PIN
#86972 - WASHER 6x15x0.2mm (6pcs)
#94398 - CAP HEAD SCREW M3x55mm (6pcs)
#94512 - CAP HEAD SCREW M4x30mm (10pcs)
#B023 - BALL BEARING 6x13x5mm (2pcs)
#B030 - BALL BEARING 10x15x4mm (2pcs)
#B032 - BALL BEARING 10x16x5mm (2pcs)
#b085 - BALL BEARING 8x16x5mm (2pcs)
#Z224 - WASHER 3x8mm (10pcs)
#Z240 - C CLIP 8mm (4pcs)
#z243 - E CLIP E3mm (10pcs)
#Z245 - E CLIP E5mm (10pcs)
#Z260 - PIN 2.5x12mm (12pcs)
#Z282 - STEP SCREW M3x14mm (4pcs)
#Z286 - STEP SCREW M3x20mm (6pcs)
#Z288 - STEP SCREW M4x20mm (4pcs)
#z303 - CAP HEAD SCREW M3x42mm (6pcs)
#Z517 - BINDER HEAD SCREW M3x8mm
#Z519 - BINDER HEAD SCREW M3x15mm
#Z520 - BINDER HEAD SCREW M3x18mm
#z526 - FLAT HEAD SCREW M3x8mm (6pcs)
#Z529 - FLAT HEAD SCREW M3x15mm (6pcs)
#Z530 - FLAT HEAD SCREW M3x18mm (6pcs)
#Z538 - CAP HEAD SCREW M3x25mm (6pcs)
#Z547 - CAP HEAD SCREW M3x20mm (6pcs)
#Z561 - TP. FLANGED SCREW M3x10mm
#z567 - TP. BINDER HEAD SCREW M3x10mm
#z569 - TP. BINDER HEAD SCREW M3x15mm
#Z573 - TP. BINDER HEAD SCREW M3x25mm
#z578 - TP. FLAT HEAD SCREW M3x12mm
#Z581 - TP. FLAT HEAD SCREW M3x18mm
#Z613 - BINDER HEAD SCREW M4x10mm
#Z619 - BINDER HEAD SCREW M4x40mm
#Z632 - TP. BINDER HEAD SCREW M4x10mm
#Z634 - TP. BINDER HEAD SCREW M4x15mm
#Z644 - TP. FLAT HEAD SCREW M4x15mm
#Z649 - TP. FLAT HEAD SCREW M4x30mm
#z661 - LOCK NUT M2.6 (4pcs)
#z663 - LOCK NUT M3 (6pcs)
#Z664 - LOCK NUT M4 (4pcs)
#Z680 - FLANGED LOCK NUT M5x8mm
#z682 - FLANGED LOCK NUT M5
#z684 - FLANGED LOCK NUT M4 (4pcs)
#z685 - WASHER 2.7x6.7x0.5mm (10pcs)
#z695 - WASHER 4x6x0.3mm (10pcs)
#z721 - SET SCREW M4x4mm (4pcs)
#Z792 - CAP HEAD SCREW M4x8mm (6pcs)
#Z877 - WASHER 8x10x0.2mm (10pcs)
#z892 - WASHER 10x12x0.2mm (10pcs)
Bodyshells and Body Accessories
#102219 - SAVAGE FLUX HP GT-2 PAINTED
Wheels and Tires
#3192 - WARLOCK WHEEL CHROME
Oils and Chemicals
#Z159 - THREAD LOCK
#Z164 - HEAVY WEIGHT GREASE (30000/GEAR
#Z181 - SILICONE DIFF OIL 1000 60cc
Tools
#z903 - ALLEN WRENCH 2.5mm
#z904 - ALLEN WRENCH 2.0mm
#Z905 - ALLEN WRENCH 3.0mm
#z950 - CROSS WRENCH (SMALL)
#z960 - TURNBUCKLE WRENCH (4mm/5.5mm)
HPI Savage Flux HP Parts Listing
Chassis Components
Drivetrain
Electronics
Hardware
#6203 - BODY PIN
Wheels and Tires
Oils and Chemicals
#Z159 - THREAD LOCK
Tools
